[Sponsors] | |||||
Rep Power: 7 ![]() |
Dear Forum,
I have my simple fluent without inlet and outlet as shown in the picture below. Model.jpg I would like to have some questions regarding the setup of the boundary conditions: - How to set up material properties for air and helium, should I set constant-density or incompressible-ideal-gas or another one? - How to set the pressure for air and helium because as you can see that the helium pressure is 0.75MPa while air pressure is 0.1Mpa. Thank you in advance for your kind helps, |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| What is difference between static pressure and gauge pressure? | aja1345 | FLUENT | 2 | May 28, 2025 03:07 |
| pisoFOAM (LES) - internal pipe flow - convergence | gu1 | OpenFOAM Running, Solving & CFD | 0 | January 11, 2018 17:39 |
| Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 06:35 |
| Discharge of Pressure Vessel into Pipe with Regulator | gajowni2 | System Analysis | 0 | October 31, 2015 19:57 |
| Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 14:19 |
