Different Velocity Plots @ Porous Boundary - CFD Post
Old   April 26, 2021, 08:43
Default Different Velocity Plots @ Porous Boundary - Ansys 18.2 - Fluent - CFD Post
OnlyCFD
onlycfd is on a distinguished road
Hello everyone,
Working on ANSYS Workbencj 18.2, have a question on how the CFD Post processes the results of the runs performed in FLUENT.
Have shown a simple case in the image file attached.
What we have in here is inlets from 2 sides, a porous body ( coefficients attached from experimental data, viscous and inertial resistances) and and one outlet on the top.
Air enters from 2 inlets, turn 90 degrees, enter the porous body and then from the exit side of the porous body, will move towards the outlet.
Model is fully converged and mass balance is correct.
When the data is postprocessed in CFD Post to understand the velocity field on the inlet to the porous body, noticed two variations of plots.
The top velocity plot in the attached image is the velocity plot on the inlet surface of the porous body
Bottom velocity plot is a velocity plot at 0.1 inch in front of the inlet surface of porous body
Herein is my confusion.
As soon as the plane of velocity plot is moved away from the inlet surface of porous body, there is a an order of magnitude change in velocity ?
Is it realistic ?
Are we plotting the velocity correctly at different locations ?
Any help or guidance would be of great help
Last edited by onlycfd; April 28, 2021 at 08:21. Reason: Detailed Explanation Added for Clarity
onlycfd is offline   Reply With Quote
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 03:13
