Dynamic mesh , Region Face
Old   May 3, 2021, 09:02
Default Dynamic mesh , Region Face
Saman95 is on a distinguished road
Hello Dears
I'm trying to move a ball along an axisymmetric line in a tube as the picture attached here. in order to this I have to choose region face on remeshing tab in the dynamic mesh mode, but it doesn't work due to two quantity that we can change in deforming zone for axis
1- Minimum length scale
2- Maximum length scale
Does anyone know how I can change these value to move the ball along the centerline?
as the simulation is run I received an error like the attached picture.
can anyone help me about this problem that I face with?
Saman95 is offline   Reply With Quote
Old   May 3, 2021, 09:11
Originally Posted by Saman95 View Post
Hello Dears
Note: the two value referred above is used to increase and decrease the node on axis in front of and behind the ball.
Old   May 4, 2021, 11:21
Adrián García
Tacitus Kilgore is on a distinguished road
Hi Saman95,
these two quantities are used for the remeshing routine in order to determine which elements are meant to be remeshed at every time step.
Likewise, remeshing will be applied on those cells whose element size becomes smaller than your minimum length scale and also on those cells with an element size greater than your maximum length scale. Therefore, make sure you chose valid values. A rule of thumb is computing the current maximum/minimum cell values and skewness so you can make yourself an idea on these quantities.
Regards
Tacitus Kilgore is offline   Reply With Quote
axisymmetric, dynamic mesh, region face
Mesh Disappering with Dynamic Mesh FaroukH FLUENT 0 February 23, 2021 18:26
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
