MRT calculation in FLUENT
Old   June 25, 2015, 04:52
Question MRT calculation in FLUENT
Vaibhav Rai Khare
vaibhavraikhare is on a distinguished road
Model Description: A room (10*10*10) in which chilled water is flowing at 14 degC into panels fitted on its ceiling. 6 heat source (100 W bulbs) were considered in the room. An air conditioner is fitted in the room to cater latent load of room.
My ultimately aim is to find Mean Radiant Temperature (MRT).
My Query is:
1. How can i make a black body in the room to find the globe temperature which helps to find MRT of room (you can find it https://en.wikipedia.org/wiki/Mean_radiant_temperature here).
If not then,
2. How can i calculate MRT (there is a macro defined in CFD post to calculate, but i am not able to understand).
vaibhavraikhare is offline   Reply With Quote
Old   September 20, 2015, 22:59
Default hi
Qureshi M Z I
m zahid is on a distinguished road
i am facing the same problem. i want to calculate the MRT for thermal comfort analysis. i am confuse about the globe temperature. have you solved the problem. please share the tips. thanks
m zahid is offline   Reply With Quote
Old   April 3, 2018, 06:21
Default Mean Radiant temperature
PRAJWAL JANARDHAN PATIL
PRAJWAL PATIL is on a distinguished road
Can you tell me how to calculate mean radiant temperature in ansys I am also struct at this point
PRAJWAL PATIL is offline   Reply With Quote
Old   May 22, 2021, 15:47
Amir_line is on a distinguished road
I have the same problem can you help me if anyone finds a solution, please.
Thanks in advance,
Amir
Amir_line is offline   Reply With Quote
help in pressure drop calculation in fluent sinaupdate FLUENT 3 July 10, 2016 05:56
Calculation of Time Average of FLUENT data in CFD-Post gautamcfd FLUENT 0 September 3, 2012 10:56
power and pumping number calculation in "FLUENT" HARI SANKAR FLUENT 1 March 29, 2011 16:20
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
How can I break a fluent calculation? enry Fluent UDF and Scheme Programming 5 April 5, 2010 19:18
