How to calculate the mass flux at a disturbed surface? |
June 2, 2021, 03:36 |
Roy
Rep Power: 8 |
Hello everyone,
I am modeling a stirred bioreactor that has air sparged into it. There is also a headspace region at the top to accommodate liquid expansion due to the air injection (using the adapt/patch method) and I use a pressure outlet BC at the top. I want to see if the air mass conservation is fulfilled in the simulation. I know m-dot at the inlet, but my question is, how can I calculate the mass flow rate of air in the outlet which is a changing surface? Your help is very much appreciated. Thank you |
bioreactor, mass conservation, multiphase flows |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 18:28 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
In flow3d, How is sediment species flow rate through flux surface and mass of suspend | Sav | FLOW-3D | 0 | March 13, 2020 03:28 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
