Velocity fluctuation distribution near a wall
Old   January 24, 2008, 10:48
Default Velocity fluctuation distribution near a wall
Matthieu
I am using Fluent 3d for simulating the trajectories of particles in a detention tank. The particles are assumed to be a discrete phase in a turbulent water flow. So, I am using the Discrete Random Walk Model in order to take into the effect of the turbulence on the particle motion.
Each eddy is defined by a Gaussian distributed random velocity fluctuation u', v', and w'. But near the bed, the velocity fluctuation is not Gaussian anymore (especially the vertical velocity) (because of bursts). So, I would like to define my own distributions for the velocity fluctuations near the bed.
Does someone know how I can access these distributions and modify them in an User Defined Function ? I would like to keep the Gaussian distribution when the wall unit, y*, is superior to a threshold value, and use my own distributions when y* is inferior to this value. Does someone have another idea to model the influence of burst on particle motion ?
Matthieu
Old   June 3, 2021, 09:40
Vincenzo Luci
vincenzolights is on a distinguished road
Originally Posted by Matthieu
;148020
Matthieu
Hello Matthieu, I know this topic is old but have you solved this problem?
vincenzolights is offline   Reply With Quote
BC set at fixedValue (0 0 0), but I get a non-zero velocity @ wall squadron OpenFOAM Running, Solving & CFD 9 May 31, 2018 10:47
CFX does not continue Shafiul CFX 10 February 17, 2011 07:57
Influece of wall velocity in the main flow marvin CFX 0 March 22, 2008 02:05
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
