Constant Residual of Turbulence Kinetic Energy and Dissipation Rate |
September 8, 2017, 11:05 |
Keith
Hi all,
I am having an issue when running a simple 2D axisymmetric model of annular flow. The flow if fully turbulent (Re approx. 7E5) and I am using the k-epsilon model with intensity (3%) and hydraulic diameter (0.009 m) as parameters and standard wall functions. The mesh is well refined and structured with a maximum aspect ratio of 3. I am employing a mass flow inlet BC and 0 Pa pressure outlet. Both walls are stationary with prescribed temperature. When I run the model, all parameters converge nicely except for k and epsilon. They are simply constant. Also, I get the issue that the turbulence viscosity ratio is limited to 1E5 (default limit set by Fluent). I have done some searching online yet the only advice is to refine mesh and correct the turbulence parameters. I believe my mesh and BCs are fine so I'm kind of stumped here. Any help would be greatly appreciated... Attached below are snaps of the mesh and residuals: mesh.PNG residual.PNG |
September 9, 2017, 08:17 |
Cees Haringa
1) your mesh is very crude. I'd advise to refine it. Use at least 20 cells in the height direction.
2) how do you have 2 walls? You are using the axisymmetric model right - that means the center should be a symmetry, not a wall. If you have walls on both sides, use 2D-planar |
September 9, 2017, 08:29 |
#3 | |
Keith
1) I refined it further and the issue is still not resolved. I ran a similar model a few months ago and it wasn't much more defined than this. The first layer thickness at the walls comes from a yplus value which I calculated as 0.3 mm. "2) This is an annular flow (between two tubes) meaning there has to be two walls. The line of symmetry is the x-axis, which is not visible from the screenshots. I have spoke with someone who advised me to use a k-omega model, as it's more appropriate than k-epsilon due to this being a "two layer model". In the k-omega model, the yplus value should <1 meaning I will need to refine more at both walls. |
September 9, 2017, 08:41 |
Cees Haringa
y+ is a dimensionless variable, so it can't be 0.3mm; how did you calculate that?
Anyway, the residuals should converge for k-e too, if it works for k-omega. Did switching to k-omega solve the problem? I also am not sure if it's allowed to set up an annular flow problem like this - I can remember from when I was a FLUENT TA that for, axisym pipe flow simulations, small offset from the symmetry axis would lead to errors when they started solving, but I don't know if in that case the supposed axis was actually set to wall. Did you try running it as planar just to check whether it would converge? |
June 20, 2021, 10:19 |
Abhishek
Rep Power: 5 |
Viscosity limit error can be resolved by increasing maximum ratio (turb. viscosity/viscosity) by 1 or 2 order. simultaneously one can also try to reduce under relaxation factor of the relevant solver up to 0.01 for few iterations until properties of interest become stable again.
convergence failure, k-epsilon model, turbulence viscosity |
Turbulence kinetic energy and dissipation rate - problem with computation | Kozan | Main CFD Forum | 0 | March 6, 2015 04:04 |
change a variable in dissipation tem of turbulence model | behest | Fluent UDF and Scheme Programming | 0 | March 28, 2014 08:31 |
how to define the turbulent kinetic energy and turbulent dissipation rate? | fanke | FLOW-3D | 4 | March 26, 2013 20:40 |
turbulent kinetic energy and turbulent dissipation rate | D_L | Main CFD Forum | 5 | July 17, 2010 02:35 |
how to decide boundary condition of turbulence energy dissipation rate? | Vincent B. | Main CFD Forum | 5 | October 28, 1999 04:07 |
