June 28, 2021, 06:32 |
Minimum Aspect Ratio
Jordan
Rep Power: 4 |
Hello all,
I am relatively new to fluent . Can someone help me with the below warning "Warning: Min. aspect ratio less than 1 at 2190 nodes" What is the significance of this warning and will this effect the calculation. I am simulating flow through a nasal cavity. Thanks |
June 30, 2021, 05:53 |
Marcin
Rep Power: 12 |
Aspect ratios concern the length:width ratio of the element - usually if this is greater than 1:3 a warning can be set to appear, but in theory aspect ratios shouldn't affect the solution
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
June 30, 2021, 06:08 |
Jordan
Rep Power: 4 |
Thank you very much
October 25, 2021, 09:29 |
Metin
Rep Power: 4 |
I also faced this issue and my solution diverged. Did you manage to solve this problem?
October 25, 2021, 11:28 |
Lucky
Rep Power: 65 |
A cell aspect ratio less than 1 means you have cells where the corners have been squished inwards compared to the faces. This is usually very bad and means the cell is really skewed and will almost always lead to divergence either locally in that cell or in the entire solution.
Locate these cells in your mesh and play with your mesh settings to make it better. |
October 26, 2021, 02:03 |
Metin
Rep Power: 4 |
I changed the method of the prism generation from uniform to last aspect ratio and this error didn't appear at all but my solution still diverges. I use the exact same sizing in Ansys mesher and I get no divergence issues with that tetra mesh. But when I use the Fluent mesher with the same sizing values, I get divergence. I used tetra and poly-hexcore mesh in Fluent mesher and the result is the same even though the max. skewness is about 0.65. Any ideas about what I might be doing wrong? I wanted to use the Fluent mesher to generate Poly-Hexcore grid.
October 26, 2021, 06:24 |
Lorenzo Galieti
Rep Power: 12 |
Check also orthogonal quality on top of the skewness. Sometimes i had good skewness but bad orth quality. What are you simulating?
October 26, 2021, 11:59 |
Metin
Rep Power: 4 |
My min ortho quality is about 0,09 and I don't fail the mesh quality check in Fluent as well. I'm simulating a multi-element F1 car wing in ground effect.
maximum aspect ratio of mesh | Weiqiang Liu | FLUENT | 4 | June 3, 2020 10:04 |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
Grid Aspect Ratio | harishameed33 | Main CFD Forum | 1 | August 11, 2012 22:35 |
pressure eq. "converges" after few time steps | maddalena | OpenFOAM Running, Solving & CFD | 69 | July 21, 2011 07:42 |
High Aspect Ratio elements | Flavio | CFX | 2 | November 24, 2006 12:01 |
