July 15, 2021, 13:58 |
Import CHEMKIN Mechanism Issue
Rep Power: 4 |
This may be a familiar mechanism to some but I am attempting to import the GRI-Mech 3.0 mechanism to model natural gas combustion that pertains to what I am doing. The kinetics and thermo data files can be found on here: http://combustion.berkeley.edu/gri-m....html#thefiles .
The problem is here they are .dat files but can only be directly downloaded as *.dat.html to my computer and so I used notepad to copy-paste them and then save them as *.inp and *.dat, respectively. After doing so, I import them in as a Chemkin mechanism in Fluent but all I get is a bunch of these "Warning! Species h2 not found in the thermo database file. Equilibrium computations involving this species will fail." about at least 2 dozen different species and it finally ends with this: "Error at host: Memory allocation failed during Chemkin mechanism import 999999: mpt_accept: warning: connection timed out after 120 seconds MPI Application rank 0 exited before MPI_Finalize() with status 2 The fl process could not be started." Any help would be greatly appreciated. |
July 15, 2021, 22:51 |
Lucky
Rep Power: 65 |
Fluent was (is it still?) limited to 50 species. You can't use the full 53 species GRIMECH from Berkely. Inside the Fluent directories somewhere though, there is a 50 species version of GRIMECH that you can use. Try and see if that is your problem.
It's looking for the H2 data in thermo.dat (which is there) but is not being read because (I think) it exceeds the 50 species limitation on the reader. I'm not sure if the limitation still exists in newer versions of Fluent. |
July 16, 2021, 09:46 |
Rep Power: 4 |
Where do I find said directories with the different version? And thank you for the solution.
July 16, 2021, 13:10 |
Lucky
Rep Power: 65 |
So you are using a very very old version of Fluent? or no?
I forget where they are. It's in a tutorial. Just search your fluent directory (where you installed Fluent) for grimech30_50 |
July 19, 2021, 12:26 |
Rep Power: 4 |
Should be the most recent version of Fluent
chemkin gri |
Flame extinction when uploading chemkin mechanism | johnleo | Main CFD Forum | 0 | May 29, 2021 02:55 |
Mechanism implementation in CHEMKIN. | q__ | ANSYS | 0 | September 22, 2020 13:07 |
How to write this chemical mechanism in my Chemkin lib? | Roh | FLUENT | 0 | September 19, 2019 06:14 |
Import chemkin mechanism into fluent | xh110120 | FLUENT | 0 | March 16, 2016 02:37 |
CHEMKIN Mechanism Import Issue | Engineer_Gokhan | FLUENT | 0 | August 14, 2015 07:30 |
