how to find mass of liquid evaporated in Fluent |
October 10, 2018, 07:38 |
vidyadhar
Rep Power: 9 |
I want to simulate evaporation from a liquid confined between two walls using VOF method in Fluent. I would like to use either evaporation-condensation model available in Fluent or the attached UDF. My queries: 1. After running the simulation, how do I know how much quantity of water evaporated. This i need to determine the amount of heat lost by evaporation. 2. If i use the UDF, should i use it under Phase Interaction or as source terms under cellZone conditions. If it is under cellZone conditions, should I add Mass source terms for individual phases and energy sources for mixture? Thanks in advance! |
August 17, 2021, 03:19 |
Kumar Pushpak
Rep Power: 7 |
Hey did you find the way to plot or calculate the evaporated mass in fluent?
Simulating liquid metal in Fluent | Shamoon Jamshed | FLUENT | 10 | April 30, 2016 08:01 |
how to find coating thickness using. fluent.... | sumeet kotak | FLUENT | 9 | January 21, 2015 02:54 |
simulating liquid metal in Fluent | Shamoon Jamshed | FLUENT | 0 | October 11, 2014 11:15 |
Liquid and evaporated mass fraction of a specie | Mentalo | OpenFOAM Running, Solving & CFD | 0 | March 24, 2014 04:08 |
How to obtain the mass fraction of evaporated diesel spray | Mnzki | FLUENT | 0 | June 17, 2012 16:22 |
