Invalid axisymmetric mesh with nodes lying below the x-axis |
August 29, 2021, 09:33 |
AMDB007
Rep Power: 4 |
I am trying to do a 2D axisymmetric flow analysis. I am facing with an issue in fluent where it shows an error saying: "Invalid axisymmetric mesh with nodes lying below the x-axis". But I am sure that my geometry ends on the x-axis and there is nothing below it. I have attached pictures for reference. You can also check the mesh that I have made. Kindly advice on How to solve this? Thankyou Edit: I have found in mesh check fluent says under Domain Extents: that my geometry starts from negative y-coordinates. So I presume that somehow some of my geometry is below x-axis (no idea how). And the solution was to move my mesh up so that nothing is below x-axis. To move it up it seems I have to use some commands like fix mesh, or mesh translate, Both of which I do not know how to do. Since I am new to this I kindly ask for guidance with steps as to how to use these commands in fluent, what to type exactly in the console command window to move my mesh up. Thankyou. Last edited by AMDB007; August 29, 2021 at 10:57. |
August 29, 2021, 16:14 |
Lorenzo Galieti
Rep Power: 12 |
Upper left of your User Interface in fluent
Mesh—> Transform —> somewhere there should be translate |
August 30, 2021, 04:27 |
AMDB007
Rep Power: 4 |
Thank you, I found it.
In order to set my lower edge boundary as axis, is there any rule that whatever edge I'm setting as axis should be exactly on the x-axis? Or can it be a little away above the x-axis and not exactly on it? |
Display Modes | |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM | guxin7005 | FLUENT | 2 | June 27, 2016 22:41 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 06:48 |
