September 8, 2021, 08:43 |
Time dependent changing geometry
Rep Power: 4 |
Is it possible to use Fluent for a time dependent simulation in which the geometry (and meshing) changes in time? The purpose is to model a solid object transported by water through a pipe. So there will be a two way coupling between the solid object and the fluid.
September 8, 2021, 10:15 |
Marcin
Rep Power: 9 |
Yes - for example, six degrees of freedom (for undeformable) or fluid-structure interaction (for deformable) bodies.
For the mesh - dynamic mesh or overset mesh. |
Inconsistencies in reading .dat file during run time in new injection model | Scram_1 | OpenFOAM | 0 | March 23, 2018 22:29 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Time dependent and geometry dependent boundary conditions in ACUSOLVE | arsroy | Main CFD Forum | 1 | December 28, 2016 07:32 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
