Need for energy equation at low speeds to prevetn divergence
Old   September 15, 2021, 02:53
Default Need for energy equation at low speeds to prevetn divergence
Adithya
Adithya_11 is on a distinguished road
Hello
I am simulating an aircraft flying at an altitude, with Re=8.8e6 and Mach=0.26
Settings- SA model, Green gauss node based, coupled pressure-velocity with time 0.1, second order.
The aircraft has this cooling intake situated above the fuselage. When I simulate it it without the intake, the solution either converges or residuals drop to 2e-6.
When I have the intake, the solution diverges at high angles of attack.
One way to prevent the divergence is by using ideal gas and sutherland' law, and hence the energy equation as well, instead of using constant density and viscosity. This prevent divergence, but my residuals now drop to 1e-5 only and the force files show greater oscillation.
Why would the energy equation stabilize this case? Does it mean that the flow is compressible at these conditions? Is there another recommended way to prevent divergence?
Adithya_11 is offline   Reply With Quote
Old   September 15, 2021, 11:07
Lucky Tran
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
Energy equation isn't relevant. You just got lucky.
You can also "stabilize" the case by simply doing a better initialization. You can also stabilize it using a smaller time scale factor. There's lots of things that can be done. CFD is not a fire and forget approach.
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 06:33
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Discretization of the continuity equation for with low compressibility Hooman Main CFD Forum 0 April 12, 2012 07:17
Low flow rate in channel results in divergence Purushothama Siemens 0 March 16, 2011 22:23
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
