Mesh Check Failed Problem
1 Attachment(s)
I am simulating a two-axisymmetric supersonic jet impinging on a flat plate. When I am rotating my mesh in fluent, mesh check is being failed every time.
I did perform a check command, still the same. (pdf attached) Please, need help on this issue. |
I think for axisymmetric your domain should be all with Y >0, but I see a -25 somewhere in the pic
Mesh Check Failed
Thank you, problem solved.
I made Ymin=0, now mesh checking is being fine. |
