LuckyTran |
September 23, 2021 00:58 |
Does it even matter? I see that both inlets have a Mach number of 1 and 2, so downstream BC's shouldn't really affect the problem as long as you set a reasonable outlet pressure that maintains the sonic conditions at the inlets.
Otherwise the inlets are overconstrained. Something has to be relaxed.
If you really care about matching all the numbers at the inlet then one of the constraints needs to become a soft constraint. That is, you iterate something else until that constraint is satisfied. For example, you could use a pressure outlet BC and then iterate the outlet pressure until the inlet pressure matches the table.
