Karla Jacinto
Rep Power: 3 ![]() |
I'm using FLUENT 2020 R2 to simulate a flow. For the inlet boundary condition, I'm using Pressure Inlet with 9 300 000 Pa for the Gauge Total Pressure, and for the outlet, I'm using Pressure Outlet with Gauge Pressure of 4 600 000 Pa. I notice that the outlet pressure is the Absolute pressure (my reference value is 0). However, for the inlet the 9,3 MPa corresponds to the total (stagnation pressure = dynamic + absolute), but I want to ignore the dynamic. Is possible to set the absolute pressure at the inlet instead of the total? Thanks for your help ![]() |
Lucky
Rep Power: 58 ![]() ![]() ![]() |
Physically it is unrealistic (darn near impossible) to fix a static pressure at a flowing inlet unless the inlet is choked (i.e. Mach number equal to or greater than 1).
What you should do, is adjust your BC setting of total pressure such that you get the desired static pressure. Use the isentropic relations. You will of course need to know your inlet Mach number. Or you can just keep guessing until you get the right static pressure. |
Display Modes | |
Regarding determinng the absolute hydrostatic pressure for air+water flow in a closed | er_ijaz | OpenFOAM | 0 | September 18, 2018 00:11 |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
forcesCoeffs - how to use relative pressure instead of absolute pressure | WhiteW | OpenFOAM Running, Solving & CFD | 2 | December 22, 2015 12:40 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
about large minus absolute pressure | richard | FLUENT | 3 | December 6, 2003 09:39 |
