September 28, 2021, 09:49 |
Create a surface on each iteration TUI
Rep Power: 7 |
I have a radial gap for which I want to compute the mass flow rate in both positive radial direction and negative radial direction. I have put a surface in this gap using an iso-clip. Then I use two iso-clips of radial velocity(positive and negative) to separate my radial inflow surfaces from my radial outflow surfaces. Each radial flow surface is assigned to a report definition to measure the mass flow rates. Now i want to update these radial inflow/outflow iso-clips at each iteration. Is this something that happens automatically or do I need to redo them each time? I tried to run the commands: surface/iso-clip radial-velocity gap-velocity-negative gap-surface -5000 0 to generate my iso-clip surfaces, but after one iteration i get the error that a surface with that name already exists and i cant update them. Any help is greatly appreciated!! |
September 28, 2021, 18:03 |
Alexander
Rep Power: 34 |
everything depends on how are you going to use that iso-surfaces
at least two possible ways here: 1. on each iteration firstly delete your gap-surface and later execute the line you've showed 2. change the name of surface was gap-surface, but it could be gap-surface-00001 , where 00001 is time. In this case you will have a huge amount of surfaces to add time you may use this line Code:
(ti-menu-load-string (format #f "surface iso-clip radial-velocity gap-velocity-negative gap-surface-~a -5000 0"(rpgetvar 'flow-time)))
best regards ****************************** press LIKE if this message was helpful |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
how to create surface which is part of the boundary surface | Messi | FLUENT | 0 | January 15, 2015 12:57 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
[GAMBIT] How to plot S pipe | mariam.sara | ANSYS Meshing & Geometry | 36 | November 7, 2013 15:22 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
