April 14, 2021, 04:02 |
Reflection Free Boundary Condition
Sanda
Rep Power: 4 |
I am conducting pressure based transient incompressible fluid flow in viscoelastic tube in ANSYS fluent and I would like to create an absorbing boundary condition in the outlet of the tube.
ANSYS Fluent already include non-reflecting outlet boundary conditions (NRBC) but only applies for ideal gas (compressible) flow. With Pressure Far Field BC, it is available only when density is calculated using ideal gas law. With Outflow BC, it cannot be used for unsteady flow with variable density. So, the last option is using UDF in the outlet of the tube and I have difficulty applying it. I found a thesis that similar to my research approach. (https://folk.ntnu.no/leifh/alumni/20...aag_Hansen.pdf) And I would like to create such boundary condition in ANSYS fluent. In page 27 of the thesis, under Section 3.2 Boundary Conditions, in Subsection 3.2.1, the author applied reflection free boundary condition at the outlet of the vessel. I have short knowledge of how to apply the boundary condition at the outlet of a vessel. I am learning UDF in ANSYS Fluent, but I am not sure how to apply boundary equation (Eq 106, page 28) at the outlet. I assume it will require to use UDM but the equation require to use the volume flow rate value from previous space step. I manage to calculate in numerical analysis but Is there a tutorial to put an equation in UDF of ANSYS fluent? Equation 106 requires to use data from the previous space exported from ANSYS so How to input a variable that need to read from the analysis? Using UDM is one of the idea but not sure how to load the data. |
October 19, 2021, 13:36 |
Lucky
Rep Power: 65 |
I don't get it. You are incompressible. You don't have waves and you don't have wave reflections. Why are you looking into BC's for removing unwanted waves?
boundary condition, fluent - udf, fluid structure interface, udf and programming |
Display Modes | |
Boundary condition setting for free surface in water tank | haiteng | FLUENT | 1 | April 6, 2020 08:55 |
Shear stress boundary condition at free surface | yummigummi | OpenFOAM Programming & Development | 0 | September 2, 2019 07:34 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 05:39 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
