Coal Combustion Modelling - Devolatilisation Products Formulation |
February 6, 2022, 18:43 |
Tulo Stone
Rep Power: 5 |
Hi All,
I am working on a coal combustion modelling problem. For the two competing devolatisation reactions, I would want to specify the VM product composition for Low-Temp Devolatilisation as 32.8 % CO, 61.0 % C2H4 and 6.2 % H2, and for the High-Temp Devolatilisation as 22.6 % CO, 72.7 % C2H6 and 4.7 % H2. I guess I've to develop a UDF for this and if anyone has done this before, will be grateful if you could advise on this. Cheers! Last edited by Tulo; February 7, 2022 at 00:27. |
May 17, 2022, 16:20 |
Alain Islas
Rep Power: 6 |
I guess you are working with DPM model?
By default, Fluent's devolatilization product is only 1 product. This is a pseudo-molecule that is further oxidized to represent the combustion of the "volatile or volatiles" gases. A turn-around to your problem might be something like: (1) define a relatively low devolatilization temperature for the pseudo-molecule. Use a single kinetic rate devolatilization model and set very fast kinetics. This will move the volatile from the solid to the gas-phase almost immediately. (2) Once that the volatile is in the gas-phase, define your two reactions, maybe
These reactions will crack the volatile into your 3 species, at different rates and compositions. |
#combustion, #devolatilisation, #fluent, #udf |
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 04:10 |
Problem on EDC model for coal combustion | lei | FLUENT | 4 | September 3, 2015 09:39 |
Gasification modelling using non-premixed combustion | nurul efha | FLUENT | 0 | November 12, 2012 03:57 |
Combustion modelling with energy source | Marc_L | FLUENT | 0 | July 13, 2010 07:58 |
Turbulent Dispersion for Coal Combustion | gravis | CFX | 2 | March 23, 2010 23:56 |
