water in tank with vortex baffles
Old   February 7, 2022, 12:34
Default water in tank with vortex baffles
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Hello, I am modeling a tank filled with water but pressurized with air at 5 bar. The outlet of the tank is equipped with a vortex breaker that is used to block unwanted air pockets to pass through. Therefore, the water should pass only.
Now , I am modeling the problem with VoF (explicit) . Phase 1 is water, phase 2 is air. Operating pressure is 5 bar. At outlet mass flow inlet for phase-2 is applied, like as if the water is going to some other source. MFR is 26kg/s. I first patch initial volume of phase 2 (air) to be like 70%. But the fluid water is not changing its position at all. That is, it remains 30%.
Please help in this problem
Regards,
SJ
Shamoon Jamshed is offline   Reply With Quote
Old   February 8, 2022, 09:32
Shamoon Jamshed
please reply,
Old   February 9, 2022, 03:40
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
don't remember exactly but there should be option to define phase in outflow BC
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   February 9, 2022, 08:10
Shamoon Jamshed
yes, it is. Infact, I did this case previously with some coarser mesh and a wider geometry but this might be the effect of the fine mesh. Do i try Implicit?
water sloshing in oscillating tank (problem using udf Define_ZONE_MOTION) Tamsu Fluent UDF and Scheme Programming 8 November 24, 2021 00:11
Heating up a water tank Seeth STAR-CCM+ 8 October 23, 2018 06:11
Setting Up a case on building an empty tank with water going into the tank Nori4U OpenFOAM Programming & Development 1 May 8, 2015 02:10
Water tank baffles - modeling the flow with tank half full A_Prakash CFX 11 January 1, 2015 10:43
[GAMBIT] Water Slosing in Water Tank iwan ANSYS Meshing & Geometry 4 October 17, 2013 18:25
