SPACECLAIM rescales dimensions of imported geometry file STL |
November 29, 2021, 15:23 |
maria chiara
hi everyone, I have a problem with stl files that reads spaceclaim.
All files are created the same way but some are increased in size once imported to spaceclaim. I have to do simulations on abdominal and intracranial aneurysms and while the abdominal ones have no geometry changes, the intracranial ones greatly increase their size. I tried to change format using OBJ, I got a smaller size than the stl but still larger than the one actually imported. Can you help me? Thank you all. |
January 5, 2022, 22:55 |
Rep Power: 4 |
1. Have you tried different settings in the 'import options' for STL or OBJ file types? By default, these are set to 'automatic detection of imported model units', but if you're getting incorrect dimensions you can manually select the system of units. Before opening the model to import, in SpaceClaim in the main design window menu, select:
File | SpaceClaim Options | File Options | STL The first item on this options page is "Import...Units" with a drop down list for: automatic, inches, feet, mm, cm, and meters (some versions of SpaceClaim also provide micrometer and nanometer units). 2. For the imported model, when you select the 'Measure' tab on the main ribbon menu, and measure the distance between two edges, faces, or points, how does the SC calculated distance compare to your expected measurement? This ratio may give you a clue to determine if it is a scale issue. 3. As a test, you could import the STL to SpaceClaim, do some minor modification, then save as an STL file, then open it with the original application program you're using (I assume an MRI or CAT application) to compare the dimension saved by SpaceClaim. 4. Also, after you open the imported file in SpaceClaim, look at: File | SpaceClaim Options | Units , to verify that SpaceClaim is displaying the model in the units you expected. This page is also where you specify the precision of a dimension, up to 1e-9m. |
rescale, spaceclaim, stl file |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
