different results under linux and windows
Old   December 1, 2021, 09:16
Default different results under linux and windows
Ning Zhou
neil_zhou is on a distinguished road
I used Fluent to simulate floating breakwaters, but I got different results under linux and windows by the same udf as you can see below:
this is the result under windows,
this is the result under linux,
here is my jou file
If someone had the same problem or if you can help me to solve that
Thank you
neil_zhou is offline   Reply With Quote
linux fluent udf
Where do you use Ansys? Windows or Linux? Does Linux have any advantages? EternalSeekerX ANSYS 1 October 28, 2020 12:51
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 17:49
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Linux to Windows (dual boot system) Alex Main CFD Forum 9 May 3, 2007 04:36
Linux and windows codes giving different results Joel Siemens 3 January 7, 2004 10:15
