Does Turbulence kinetic energy change by the hydraulic diameter at constant Re ? |
December 12, 2021, 10:03 |
Emre
Hello, i study on a constant re=100.000, and my two model has a wide difference on TKE. M1 has 1m hydraulic diameter while M2 model has 0.2m. At constant RE for both of them. Waiting for your helps. Thank you.
December 13, 2021, 03:07 |
Lucky
Rep Power: 65 |
Indeed turbulent kinetic energy is a dimensional quantity. Your velocity and length scale are different for both cases so of course the tke will change correspondingly.
The typical normalization for tke is scaling it by the velocity scale, which gives you turbulence intensity. |
aerodynamic, cfd, tke |
Calculation of turbulence kinetic energy and dissipation rate | Mondal131211 | OpenFOAM Pre-Processing | 1 | May 29, 2020 04:17 |
Turbulence kinetic energy and dissipation rate - problem with computation | Kozan | Main CFD Forum | 0 | March 6, 2015 04:04 |
Problem with Turbulence Kinetic Energy | Davide_sd | FLUENT | 22 | August 7, 2014 13:57 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
Why FVM for high-Re flows? | Zhong Lei | Main CFD Forum | 23 | May 14, 1999 13:22 |
