Energy equation is not converging
Old   December 13, 2021, 09:37
Default Energy equation is not converging
Gaurav Kumar
gauravkmr is on a distinguished road
Hello everyone,
I am simulating a conjugate heat transfer problem, where heat is transferred from solid to fluid. But some time after I on energy equation, temperature is limited to problem occurs and energy equation doesn't converge, what should I do?
gauravkmr is offline   Reply With Quote
Old   December 14, 2021, 00:27
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
what do you mean here? residuals are not going down?
the reason is the temperature limit is met.
change the limit.
if this limit was set due to physics then you should change your model the way this limit would never be met
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   December 14, 2021, 00:45
Gaurav Kumar
I have changed the limit according to physics of the problem and temperature limited to error occurred. I am using SST k-w model. Residuals are not going down and the temperature of the solid body keep increasing.
Old   December 14, 2021, 02:37
Alexander
most likely you have problems with mesh
best regards
Old   May 2, 2024, 23:56
Default problem with mesh
Ashutosh Sharma
ashutosh46 is on a distinguished road
Hi, i was also experiencing same problem some time ago. The reason for energy equation divergence is the misalignment of the heat transferring control volumes (mesh). This problem need to be solved by improving the mesh. sometimes, contact faces of two bodies need to set share topology feature. I am not sure about your problem but i hope this may help.
ashutosh46 is offline   Reply With Quote
Energy equation in rhoCentralFoam (revisited) usv001 OpenFOAM Programming & Development 4 September 6, 2024 08:51
Energy equation - where is the turbulent kinetic energy? usv001 OpenFOAM Programming & Development 1 January 25, 2022 16:04
Error in computing Energy equation faab OpenFOAM Running, Solving & CFD 0 February 3, 2017 14:04
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Energy equation convergence problem Reza Main CFD Forum 0 August 27, 2003 14:09
