Dynamic mesh stability problem
Old   December 17, 2021, 04:31
Default Dynamic mesh stability problem
lzhaok6 is on a distinguished road
Dear all,
I've had a stability problem simulating a transient fluid-structure interaction problem (internal flow in pipe) using FLUENT intrinsic FSI solver. Whenever the dynamic mesh is turned on, instability occurs with growing continuity residual and sudden and drastic change of pressure at each time step. To demonstrate this problem, I've made a very simple pipe section (aluminum) with water inside flowing at 6m/s. k-omega SST model is used. Please see the pictures attached for the weird pressure behavior. If the dynamic mesh is turned off (only exchange pressure and displacement without moving the mesh), the pressure behavior becomes stable and normal (positive pressure at inlet and gradually decreased to zero at outlet) and the simulation is stable. So I'm pretty sure the instability comes from the dynamic mesh module.
Things I have tried so far but did not solve the problem:
1. Refine the mesh.
2. Decrease the residual.
3. Using implicit mesh update.
4. Decrease the time step size (smaller dt seems to be more unstable).
I've also attached the screenshots for my other configurations (fluid_sym is symmetry surface of the pipe section which I set as deforming).
Thanks for your attention!
File Type: jpg Pressure contour in two consecutive time steps.jpg (38.7 KB, 12 views)
lzhaok6 is offline   Reply With Quote
Dynamic mesh setting problem Youwu FLUENT 7 June 1, 2020 06:47
Dynamic mesh problem entlit FLUENT 0 June 9, 2016 05:19
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Dynamic mesh update problem. David FLUENT 3 March 15, 2012 06:02
CFD-3D flow problem using Dynamic mesh method. Sar_mech FLUENT 1 November 27, 2008 22:17
