[Sponsors] | |||||
Reza
Rep Power: 0 ![]() |
Hello friends
I am new to simulating with Ansys Fluent. I have a question about the range of y+ and the turbulency model to be used. I want to simulate airflow inside a spiral channel with constant heat flux on the walls. As I read in the articles, the y+ should be below 1 for heat transfer simulation. On the other hand, for the k-e turbulency model, y+ should be 30 to 300. I want to know what do you suggest for this problem? Which y+ and turbulence model should I take? Many thanks for considering my request. |
Lucky
Rep Power: 68 ![]() ![]() ![]() |
In general, lower y+ is always better assuming you use the appropriate wall treatment.
The standard k-epsilon model using specific wall functions should have a higher y+. And frankly, I don't know of anyone that actually prefers this particular asinine combination. Most people use better turbulence models and use the enhanced wall treatment (in other words, an all y+ approach). If you can afford the lower y+ ~ 1, go for it by all means. It's just better. No one will complain. |
Reza
Thank you, LuckyTran, for your answer. I also prefer to deal with y+ lower than 1. For this reason, I used inflation close to the walls to reduce y+. I used the k-omega SST turbulence model. For convergency, I had to use the first-order method for the density and energy; otherwise, the residuals wouldn't reach the proper value (e-3 for continuity, momentum, and turbulence, and e-6 for energy). Do you think my approach is good enough to achieve accurate results?
physics baali
Rep Power: 7 ![]() |
i dont know exactelly but i think you must choose Y+=1
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
| Efficiency of centrifugal compressor - Adiabatic walls vs CHT | Burken | CFX | 0 | May 11, 2018 13:53 |
| Interphase mass transfer of a reaction | cfx_ws1992 | Main CFD Forum | 0 | May 15, 2017 22:42 |
| Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 23:53 |
| heat transfer at walls | ioana | CFX | 7 | May 17, 2004 10:26 |
