UDF for Scroll Compressor 3D
Old   December 29, 2021, 22:18
Default UDF for Scroll Compressor 3D
İstanbul
0xyqen is on a distinguished road
I am trying to simulate 3D scroll compressor and expander.
The remeshing process is not what I want, so it gives a negative volume error in first iteration for 3D.
2D https://youtu.be/MkMrTy_3OUY
I have a problem with UDF file. when I rotate the orbit scroll with the DEFINE_CG_MOTION command, the meshes stretch a lot and give a negative volume error.
What command will I use? DEFINE_GRID_MOTION?
Why is remeshing proses not working properly?
Is UDF enough for orbiting scroll only? or Do I have to make a udf file to change the nodes in fixed scroll?
CAD file, mesh settings and timestep are the same as in the article.
What is the mistake I made in the UDF file that the remeshing process is such nonsense.
0xyqen is offline   Reply With Quote
udf for one dimensional linear motion based on force maccheese Fluent UDF and Scheme Programming 2 September 1, 2019 03:18
Save output of udf in another udf! JuanJoMex FLUENT 0 February 8, 2018 13:43
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
