TUI Command for switching Initialization method from Hybrid to Standard
I'm trying to switch the initialization method from hybrid to standard using TUI commands. Alternatively, I want to initialize through the standard initialization. So far, I was able to define the settings within the standard initialization: /solve/initialize/compute-defaults/velocity-inlet "i_000" The above command helps identify which inlet it would compute from. /solve/initialize/list-defaults The above command helps identify that the inlet has been initialized properly. However, when actually getting it to initialize, the only option I see is hybrid initialization. For reference, see the image below: https://ibb.co/H7Tk5g8 |
