difference between throat and exit in nozzle
Old   January 4, 2022, 09:23
Default difference between throat and exit in nozzle
joomi lee
nozzle master is on a distinguished road
In order to analyze the flow inside the nozzle, a 2D Axisymmetric nozzle is simulated.
Other nozzle model is fine. They have same mass flow rate between throat and exit in nozzle.
But only one thing have not same mass flow rate.
Mass flow rate of throat is about twice more than the mass flow rate of exit.
What happen this situation?
What is wrong ... ? :혼란스러운::혼란스러운:
nozzle master is offline   Reply With Quote
Old   January 4, 2022, 12:54
Lucky
말도 안돼,
There's no way that can be a converged result. Have you plotted contours of pressure/temperature/velocity throughout the domain? It's probably all bonkers.
rhoCentralFoam - Supersonic nozzle BC's retroglass OpenFOAM Running, Solving & CFD 10 April 5, 2024 13:24
Calculating frictional losses in cd nozzle DA6righthand Main CFD Forum 3 June 8, 2017 20:23
Shock in CD nozzle? rabbitmelon CFX 7 April 10, 2017 12:13
supersonic (Laval) nozzle, unphysical Mach number Judith CFX 7 August 14, 2014 19:28
calculate nozzle length oe Main CFD Forum 0 July 30, 2008 15:06
