the differences between Radiation Temperature and Static Temperature
Old   January 9, 2022, 11:07
Default the differences between Radiation Temperature and Static Temperature
xingangzheng
ustbdynamic is on a distinguished road
Hello Everyone,
I am simulating a radiation problem using P1 model. It is found that there are two Temperatures listed in the Contours. One is Radiation Temperature, the other is Static Temperature. Though the contours depicted, no relationship was found between them.
So what is the difference between them?
and the incident radiation G is calculated by which one of the following:
4. * SIGMA_SBC*pow(Radiation Temperature, 4), or
4. * SIGMA_SBC*pow(Static Temperature, 4).
Thank you
ustbdynamic is offline   Reply With Quote
Old   January 9, 2022, 18:57
Lucky
Radiation temperature is calculated from G via the inverse of the relation you wrote.
Old   January 9, 2022, 21:45
xingangzheng
Thank you LuckyTran.
That is to say the radiation temperature is just a characterization of radiation intensity.
For example, the local higher Static Temperature does not mean having a high radiation flux. But the local higher Radiation Temperature indicates there must be a high local radiation heat flux.
I don't know if I understand correctly.
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Static Temperature / Opening Temperature JulianP CFX 12 April 10, 2019 19:00
Static temperature and Total temperature Jong-Yoon FLUENT 0 September 25, 2016 02:42
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation volleyHC CFX 5 April 3, 2016 06:41
Bulk temperature Tf is obtained from total or static temperature? NPU_conanxie FLUENT 0 March 30, 2011 06:56
