Spectral resolution of FFT in a acoustic simulation
1 Attachment(s)
Hi everyone, I am trying to simulate the tonal noise of a centrifugal fan (with FW-H analogy model) and have a problem with the Post-processing.
To represent the tonal noise I have created a FFT but it seems that there are too little data points hence the resolution of the graph is not sufficient. I have tried decreasing the time step but to no avail. Is there something that I have missed? Additional info: I have set the write frequency in the acoustic sources tab to 1 |
Resolution is limited by how long you record the signal, so run your simulation longer if you want more resolution. If say this data corresponds to time = 0 to 1 seconds of physical time. Run it for 2 seconds.
Maximizing the sampling frequency by setting it to 1 merely allows you to to reach a higher maximum frequency on the FFT (i.e. the range). It doesn't improve resolution. |
Thank you!! I finally get it. I still have one question. My frequency max is set to 10 kHz. Do you know how to increase it?
What's your time-step size? Is it 1e-03 seconds?
5e-5 seconds
