Spectral resolution of FFT in a acoustic simulation |
March 2, 2022, 10:52 |
Rep Power: 4 |
Hi everyone, I am trying to simulate the tonal noise of a centrifugal fan (with FW-H analogy model) and have a problem with the Post-processing.
To represent the tonal noise I have created a FFT but it seems that there are too little data points hence the resolution of the graph is not sufficient. I have tried decreasing the time step but to no avail. Is there something that I have missed? Additional info: I have set the write frequency in the acoustic sources tab to 1 Last edited by Leoma; March 2, 2022 at 10:53. Reason: Additional picture |
March 2, 2022, 12:03 |
Lucky
Rep Power: 65 |
Resolution is limited by how long you record the signal, so run your simulation longer if you want more resolution. If say this data corresponds to time = 0 to 1 seconds of physical time. Run it for 2 seconds.
Maximizing the sampling frequency by setting it to 1 merely allows you to to reach a higher maximum frequency on the FFT (i.e. the range). It doesn't improve resolution. |
March 7, 2022, 11:11 |
Rep Power: 4 |
Thank you!! I finally get it. I still have one question. My frequency max is set to 10 kHz. Do you know how to increase it?
March 7, 2022, 14:33 |
Lucky
Rep Power: 65 |
What's your time-step size? Is it 1e-03 seconds?
March 7, 2022, 16:12 |
Rep Power: 4 |
5e-5 seconds
acoustic analogy, fft, fwh |
write bc data and read it for other simulation | jdp810 | SU2 | 1 | May 8, 2021 17:04 |
Acoustic simulation using CFX | AS_Aero | CFX | 0 | March 4, 2021 04:23 |
Mapping Field Data for Mesh Regions from Another Simulation | veterator | OpenFOAM Pre-Processing | 1 | July 10, 2018 05:28 |
restarting paused transient simulation using reactingFoam | JMDag2004 | OpenFOAM Running, Solving & CFD | 1 | August 10, 2015 10:15 |
How to decide mesh resolution for Large Eddy Simulation (LES) and for SAS-SST model | juzer_700 | CFX | 3 | May 8, 2015 03:02 |
