Deciding the flow of the models
Old   May 16, 2022, 08:42
Default Deciding the flow of the models
Faris
Faris Qusyairi is on a distinguished road
Currently I am working on simulation for lubrication film thickness simulation analysis from different surface roughness on different sliding sizes. So basically I decided to run the simulation of lubricant film between a piston ring and cylinder liner. But now I am having a problem on how to calculate the Reynolds number so I can decide if the flow is laminar or turbulence. I will attach the picture of the model below.
https://drive.google.com/file/d/1DHB...ew?usp=sharing
Density of oil: 856 kg/m3
Viscosity of oil: 0.106715 kg/ms
Faris Qusyairi is offline   Reply With Quote
Old   May 16, 2022, 09:40
Lucky
In general it should be laminar or else the film loses its load carrying capacity. If you are simulating a working piston-cylinder engine, it will be laminar.
Old   May 16, 2022, 11:29
Faris
May i know what will be the suitable 2D model if i would like to run a turbulence flow?
Old   May 16, 2022, 12:05
Lucky
If you're wondering if a lubrication film should be laminar or turbulent, then it should be laminar or it wouldn't be a lubricating film (or at least it would be a bad one).
If you're asking how to determine if it is laminar or turbulent based on Reynolds number, then you're looking for the Couette flow Reynolds number which is the shear (sliding) velocity and gap height, and that has a critical Reynolds number around 2000.
If you're asking where in the universe you can find a lubricating film that is turbulent, they exist in many places at non-optimal conditions for typical oil bearings that people get paid to design out of their systems. They also exist in non-lubricating film s(i.e. water films). So I must ask why? Is this some sort of academic exercise?
Old   May 16, 2022, 13:38
Faris
Thank you for the reply and info, now I have better understanding of what I am doing, Yes this is some sort of academic exercise. I am having trouble because i dont know how am I supposed to find the effects of lubrication film thickness on different surface roughness if the flow is laminar. Because in ansys fluent surface roughness option is off for laminar flow. Or maybe you have any ideas on how am I able to solve the problem? I am new to this software.
Old   May 17, 2022, 03:45
Lucky
Have you done any literature survey?
Surface roughnesses are usually much smaller than the diffusive length scale in a laminar flow and laminar flows (from a wall shear stress perspective) are basically unaffected by typical surface roughnesses–unless your roughness is an elephant. If the flow is affected by the roughness then you should grid it and just brute force it with DNS. If you try to look up the friction factor in a laminar pipe flow for example, it's independent of surface roughness.
On the roughness options available in Fluent, they are for modeling turbulent flows and no options exist for laminar flows. Even for turbulent flows, they barely have any effect.
T-Junction water flow and turbulence models indy07cz OpenFOAM Running, Solving & CFD 0 January 21, 2020 07:07
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Please give me a general description about different types of flow models sanjiiv FLUENT 0 June 7, 2016 03:44
Modelling valves/orifices using interface models DarrenC CFX 5 June 3, 2014 07:14
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
