Capillary modeling
Old   May 17, 2022, 04:53
Smile Capillary modeling
D. Fai is on a distinguished road
Dear Sir/ Madam,
I hope my message finds you well.
I am trying to model the flow in a capillary using FLUENT.
Dimensions (L = 1000 mm, D= 1.5 mm).
Problem: I have got numerical errors related to the large ratio (L/D).
Is there any way to overcome this problem?
I have found in the literature that applying dimensionless length and radius might help, but I couldn't figure out how to do so.
If you have any suggestions/course/book, on how to model the flow inside such a capillary, I would really appreciate your time and experience.
I wish you a good day
D. Fai is offline   Reply With Quote
Old   May 18, 2022, 02:48
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
dimensionless length sounds interesting to me
may I ask you what exactly are you trying to model and which results do you expect to get?
depends on your goals, mesh structure may be different
the structure of your domain is also playing role here from my point of view: i mean location of your boundary conditions.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   May 18, 2022, 05:13
Dear Alexander Z,
I am trying to model Capillary membrane - horizontal position(dimension Length=1000mm, Diameter= 1.5 mm).
I would like to see the velocity profile of water enters from the right side, and flow out from the wall. But as I said before, I am facing numerical errors due to the large ratio L/D.
I wish you could help me, or suggest a course/ method, how to overcome this problem.
I wish you a good day sir
Gas flow through capillary toyonline Main CFD Forum 0 January 19, 2015 05:35
[ANSYS Meshing] Issue with modeling dynamic capillary rise in a capillary tube cp703 ANSYS Meshing & Geometry 13 March 22, 2013 21:11
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 12:48
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 15:49
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 10:21
