Do I Need to Return the Sliding Mesh Preview to the Original Position |
July 12, 2022, 11:12 |
Nate Werner
Rep Power: 3 |
I am applying a sliding mesh that contains a rotating wing inside of a larger stationary zone. Here is a top view of the geometry from the ANSYS meshing tool showing the original position. Hopefully, the image has been uploaded.
In ANSYS FLUENT, when I preview the mesh it obviously moves the sliding mesh to a new position. Do I need to return it to the original position before running the calculation? And if so, how do I do that? Thank you |
July 12, 2022, 11:40 |
#2 | |
Void_CFD-user
Rep Power: 4 |
July 12, 2022, 11:42 |
Nate Werner
Rep Power: 3 |
OK, that is unfortunate. I will keep that in mind for the future.
preview mesh motion, sliding mesh |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 12:38 |
No matching function error: Phase change source term added to interMixingFoam | wavefunction | OpenFOAM Programming & Development | 2 | February 4, 2022 07:46 |
Sliding Mesh Problem | cturutoglu | FLUENT | 12 | September 2, 2016 08:58 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Sliding Mesh | Sridhar | FLUENT | 0 | August 23, 2002 14:54 |
