Contour is not showing on the right surface!!!
Hi all,
I have a cylinder pipe where the flow is in the z-direction. I wanted to see the species' concentration in the porous wall. Therefore, I created a plane using 3 points method, and I checked the yz plane was placed correctly (that only covered the wall portion). However, when I used the contour, it showed up as a complete yz plane at x=0. Does anyone how to fix this? Thanks in advance! |
Problem is solved!
I used isosurface and it worked now!
