Airfoil Convergence Problem at High Angle of Attack |
July 20, 2022, 09:26 |
Arash
Rep Power: 3 |
Hi
I'm simulating an airfoil in range of 0-18 (deg) angle of attack, And I have convergence problem at 16...18 degree. flow is incompressible, Geometry is fixed and flow has direction, K-Omega SST turbulent model at default settings, Reference values are set (Area = chord length), Standard initialization from inlet, |
July 20, 2022, 09:50 |
#2 | |
Void_CFD-user
Rep Power: 4 |
July 21, 2022, 18:19 |
To some extent done
#3 | |
Arash
Rep Power: 3 |
It was a meshing problem and I tried to refine the mesh and finally, It was Solved, It was a steady state modeling, Therefore, I was unable to use a pseudo time step, I did it with FMG initialization, But it took much time and iterations. All the best Arash |
convergence, divergence, fluent, k-omega sst |
high AoA Airfoil convergence | ExtroGG | FLUENT | 0 | February 18, 2021 13:37 |
Pitching Airfoil angle of attack | albinjohny | OpenFOAM Running, Solving & CFD | 11 | November 16, 2018 05:31 |
2nd Order Convergence Problem for 3D Airfoil | turkmengokce | OpenFOAM Running, Solving & CFD | 1 | September 10, 2015 07:20 |
Problem with airflow over naca0012 and angle o f attack | Lucas | OpenFOAM Running, Solving & CFD | 2 | February 18, 2011 13:13 |
Unreal vortices in NACA0012 at high angle of attack | parvez2683 | FLUENT | 1 | September 18, 2009 12:27 |
