Simulation results of cfx and fluent are different.
Old   August 10, 2022, 01:53
Default Simulation results of cfx and fluent are different.
Junyeol
dhehdxhdaus is on a distinguished road
Hello, I am a student majoring in solid mechanics simulation.
I am currently trying to study fluid dynamics simulation.
I ran the same fluid simulation using fluent and cfx respectively.
The inlet mass flow is 0.0007 kg/s and the outlet static pressure is 90 mmhg.
It's a simple static simulation of a single S-shaped tube.
Both set the fluid as water, which has the same viscosity.
I don't know why the wall shear contours of the two simulations are so different.
thanks for your help.
dhehdxhdaus is offline   Reply With Quote
Old   August 10, 2022, 02:20
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
as the difference about 0.2% check all settings. models you are using, bc, mat properties, so on
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
CFX vs. FLUENT turbo CFX 4 April 13, 2021 08:08
Different Results using CFX and Fluent ka1 FLUENT 0 August 15, 2018 05:49
Transfer Fluent Results to CFX yanqoue FLUENT 0 September 9, 2016 09:18
Different result in CFX and fluent for mass trans.? is segregated better? ftab CFX 7 September 27, 2012 07:57
CFX results as initial value for FLUENT 6.3 mohammad FLUENT 1 January 23, 2012 06:39
