Unit in inlet & report definitions
Like Tree2Likes
  • 1 Post By AlexanderZ
Old   September 23, 2022, 00:04
Default Unit in inlet & report definitions
Joko
Jack91 is on a distinguished road
Hi guys, i try to run simulation of my pelton turbine. It's been 8 months since i start this research, create a geometry in ACAD, learn ansys, run the simulastion, etc. it would be very helpfull if you guys can help me so i can finish my college already.
First, i want to input inlet volumetric flow around 1.6 m3/s to run my pelton turbin simulation. Why the unit in inlet velocity magnitude is "m/s"?
Is it possible to convert "m3/s" to "m/s"?
What should i do if you cant convert "m3s" to "m/s"?
And second, why the unit in my omega is "Hz"?
I get my omega from vel max (facet maximum) then create new expression by using formula vel max/r[m]. When i try to run, the unit in omega plot becomes "Hz". I know you can convert "Hz" to "Rad/s" but still, if i can get my unit correctly in the plot, i wouldnt bother to make another graphic in in excel.
Thanks.
Jack91 is offline   Reply With Quote
Old   September 26, 2022, 02:31
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
1. divide 1.6 m3/s but the area of inlet
2. m/s / m = 1/s which is Hz
Jack91 likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   September 26, 2022, 02:45
Joko
Thank you sir
Rearding this answer
I need further explanation. What do you mean by "but the area of inlet"?
The lenght? diameter of the nozzle? Or something else?
Pitc below is my design.
Old   September 26, 2022, 03:40
Alexander
i mean area of the hole (in reality) through which gas passes with desired flow rate
Jack91 likes this.
best regards
Old   September 26, 2022, 04:26
Joko
Thank you kind sir.
Your answer is very helpful.
fluent, omega, units, velocity magnitude
Problem with velocity inlet using FireFoam Jean_S OpenFOAM 0 July 5, 2021 04:40
Creating a Report Definitions Surface Plane Ben_Hmouda Main CFD Forum 2 March 15, 2021 12:18
K-Omega-Epsilon BCs for suction inlet CFDBro OpenFOAM Running, Solving & CFD 0 March 27, 2018 18:28
multiphaseInterfoam non-constant inlet kaaja OpenFOAM Running, Solving & CFD 4 February 23, 2018 02:04
Inlet Velocity in CFX aeroman CFX 12 August 6, 2009 18:42
