September 21, 2022, 08:06 |
fluent hex to tet interface
Rep Power: 6 |
hello everyone,
I am using Fluent Meshing to generate a hexcore mesh with tet transition to prism layers from a tri surface mesh. The transition from hex to tet is done by splitting each quad face into 2 tris. After i import the mesh back into ICEM, i fix the uncovered faces which creates a part containing all quad & tri elements at the transition. I then separate those elements into 2 parts (UNCOV-QUAD & UNCOV-TRI). Both parts share their nodes and the tri part has the twice the amount of faces as the quad part. When i load the mesh into fluent, both parts get defined as wall. I would like both to be interior. My first idea was to define both as interface. But i am unsure if this is the most efficient and accurate way of doing this. Would a transition with pyramids be better? In an earlier version of fluent, back when "/mesh" was called "/grid", there was a function called "/grid/make-hanging-interface", which would do exactly what i want. Does anyone know the equivalent in fluent 18.2? thanks for your help in advance |
fluent, hanging nodes, hexahedral mesh, pyramids mesh, tetrahedral mesh |
How to use the CFX periodic interface | zhihuawan | CFX | 61 | January 15, 2018 16:20 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
pimpleDyMFoam - rho not found | maasyraf3 | OpenFOAM Running, Solving & CFD | 10 | June 5, 2017 13:05 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
[Other] mergeMatchPairs with arcs | vainilreb | OpenFOAM Meshing & Mesh Conversion | 1 | August 5, 2013 08:11 |
