Unit in inlet & report definitions
Hi guys, i try to run simulation of my pelton turbine. It's been 8 months since i start this research, create a geometry in ACAD, learn ansys, run the simulastion, etc. it would be very helpfull if you guys can help me so i can finish my college already.
First, i want to input inlet volumetric flow around 1.6 m3/s to run my pelton turbin simulation. Why the unit in inlet velocity magnitude is "m/s"? Is it possible to convert "m3/s" to "m/s"? What should i do if you cant convert "m3s" to "m/s"? And second, why the unit in my omega is "Hz"? I get my omega from vel max (facet maximum) then create new expression by using formula vel max/r[m]. When i try to run, the unit in omega plot becomes "Hz". I know you can convert "Hz" to "Rad/s" but still, if i can get my unit correctly in the plot, i wouldnt bother to make another graphic in in excel. Thanks. |
1. divide 1.6 m3/s but the area of inlet
2. m/s / m = 1/s which is Hz |
1 Attachment(s)
Thank you sir
Rearding this answer Quote:
The lenght? diameter of the nozzle? Or something else? Pitc below is my design. |
i mean area of the hole (in reality) through which gas passes with desired flow rate
Thank you kind sir.
Your answer is very helpful. |
