Creating different meshes in two different geometries in contact with each other
Like Tree2Likes
  • 1 Post By AlexanderZ
Old   September 29, 2022, 10:12
Default Creating different meshes in two different geometries in contact with each other
Z.N.A is on a distinguished road
Hello everyone,
I'm trying to do a validation study, but I have a few problems with the mesh part.
I have a solid plate and a cooling channel geometry with refrigerant flowing through it. Since it is symmetrical, I divided it into two and applied the symmetry boundary condition.
The problem is I want to mesh two fluid and solid domains differently. But I did not understand how to do it. I tried various methods. You can access it from pdf.
Meshing_question_compressed.pdf
How can I mesh them iindependently?
(I am trying to learn cfd. thank you for your patience)
Z.N.A is offline   Reply With Quote
Old   September 30, 2022, 02:06
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
to mesh fluid and solid separably you may do following:
1. simply make 2 different meshes and load them into fluent one by one, assign interface
2. in design modeler (geometry) put fluid and solid zone into different parts (so you will have 2 parts). Go to mesher, created mesh. In name selections define interface between fluid and solid: you need 2 surfaces -> surface of solid part adjusted to fluid and surface of fluid part adjusted to solid (they are overlapped)
however, personally I think you don't have any problems with model, try to use other setting. Use more iterations.
Z.N.A likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   September 30, 2022, 09:00
Thank you for your reply AlexanderZ,
As you said , I named one of the conflicting faces as "interface" in the mesh section. When I open the Fluent, I encountered a message like this:
Fluent can try to improve the mesh quality via the TUI command
/mesh/repair-improve/improve-qualityNote: zone-surface: cannot create surface from sliding interface zone.
Creating empty surface.
When I searched for this error on the internet, I read that I need to introduce these overlapping surfaces in Fluent.
Did I understand correctly or should I have done the naming differently?
Old   October 4, 2022, 02:15
Alexander
to make it more clear for you, mesh your zones separately, then load in fluent one of them and append another. Next define interface
Z.N.A likes this.
best regards
Old   October 4, 2022, 04:03
Thank you so much AlexanderZ. I solved the problems.
[ANSYS Meshing] Overlapping contact region with cyclic dependencies mkkim400 ANSYS Meshing & Geometry 1 December 19, 2018 09:02
inaccurate contact angle capturing in high shear/viscousity flow chery1986 OpenFOAM Running, Solving & CFD 0 October 23, 2015 01:14
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
Problems with Meshing: Collapsed Cells Emmanuel Resch Siemens 1 July 30, 2007 04:02
where to find free geometries and meshes? Xiongjun Shao FLUENT 2 June 30, 2002 17:36
