Sectional Lift & Drag
Old   October 6, 2022, 16:42
Default Sectional Lift & Drag
Pierce
PierceH is on a distinguished road
I have a resolved wing on Fluent and want to extract sectional drag at given locations. I tried to do this by creating slices on my wing then performing a surface integral summation of a custom field function that for pressure drag would read X_face_area*Cos(AoA) + Z_face_area*Sin(AoA)*P_static. And to verify this will integrate to pressure drag if I am doing so for the whole aircraft, so there's no issue with this setup. However if I do it for a 2D wing section, I then have the issue where the face areas are not 2D, they're for the entire cells where the desired section cuts the surface grid and so I have a drag value that is acting over a given area and then how do you calculate that area....
Any suggestions?
PierceH is offline   Reply With Quote
Sectional lift and drag coefficients duybk2501 FLUENT 2 August 3, 2022 09:24
Calculation of lift and drag coefficients on airfoil CoolHersheys OpenFOAM Post-Processing 5 September 27, 2021 07:04
Drag Force Ratio for Flat Plate Rob Wilk Main CFD Forum 40 May 10, 2020 05:47
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
Sectional Drag and lift coefficient? eRzBeNgEl OpenFOAM 7 November 27, 2013 22:26
