Boundary conditions in fluent are ignored
i am a beginner in fluent and have a problem with my polymer nozzle flow. I set a velocity inlet condition: 0.01364 m/s, supersonic pressure = 0 Pa and a pressure outlet condition (atmosphere pressure): gauge pressure = 0 Pa (my first try was: gauge pressure = 101325 Pa), Backflow Pressure Specification = total pressure. The rest boundaries are walls with default settings. - Solver: pressure-based - steady - laminar - without energy Equation - The material is pa12 as fluid - solution method: coupled, Rhie-Chow: distance based, Least Squares Cell Based, Second Order, Second Order Upwind During initialization the message: pressure information is not available at the boundaries. And as result I do not have a flow, the velocity is zero. And the pressure is different from my outlet pressure. Where is the error? Does anyone have an idea? I hope you understand my words! Thank you! |
the boundary conditions are correct. I think something is screwed up in your geometry
Which gauge pressure is the right one for the pressure outlet at atmospheric pressure? |
Depends on what operating pressure you choose. (google the fluent button location)
The "real pressure" is operating pressure + gauge pressure. So if you set the operating pressure to 0, the gauge pressure is 1 atm, if the operating pressure is 1 atm, the gauge pressure is zero. Keep in mind that, if you solve incompressible flow, the absolute value of pressure actually doesn't matter. |
OK, I think I understand. Thank you!
But what does ist mean: "the absolute value of pressure doen't matter"? I am student, simulate for our chair and am not yet so proficient in cfx application. What could be the error of geometry. I am only simulating the fluid in the nozzle. There is a rod axially in the nozzle. Could that be the problem? |
it is not abouyt cfx, it is about physics: in incompressible flow, what matters is the pressure gradient ( or difference) because it moves things. ( check navier stokes equations! there's only pressure gradient)
In compressible flow instead (e.g. air), the absolute pressure value matters because it goes into PV = nRT and determines the density The error in your geometry: I have no idea, especially because you didn't post any pictures :) |
1 Attachment(s)
Oh that's what it was referring to in your message. Sure, that's right.
I imported the geometry as a step (from inventor). The inlet is on the left/upper side; the outlet is at the bottom. The rest parts are walls (including the rod surface). (See pdf) |
