Problem in rising outlet water temperature in PCM based System
1 Attachment(s)
Hello, I hope you are doing well, I have a question and I would be grateful if you could guide me I am simulating the below system,
System Double tube heat exchanger ************************************************** ************ Inlet domain is water::::::: Boundary condition::::: Tinlet=30 C Inlet= mass flow inlet=0.02 kg/s Outlet= Outflow ************************************************** ******** Outer domain is PCM::::: Boundary condition:::: Outer Wall under the influence of Irradiation 900 W/m^2 melting temperature=54 C ************************************************** **************** The initial temperature of system=30 C ************************************************* But I have a problem, The outlet water temperature does not change. I changed the length, PCM volume, and shape of the water domain( U shape and ...), It still hasn't changed. Please help me, thanks Thank you in advance for your time |
