Volumetric Heat Loss UDF - Surface Area and Surface Heat Flux
I am trying to write a UDF in Fluent that will first calculate the surface area of any given wall, then obtain the surface heat flux through that wall. I will then need to supply those values to a DEFINE_SOURCE UDF that will be used to calculate volumetric heat loss through the corresponding cell zone. What macros will I need to use to obtain the surface heat flux from the wall, store the surface area and heat flux in a specified memory location, and then pass the surface area and heat flux values to the DEFINE_SOURCE UDF? Any assistance would be greatly appreciated. Thanks |
you may take a look here as a start
https://www.cfd-online.com/Forums/fl...fs-fluent.html I'm not sure if there is macro to get heat flux through the wall probably, you would need to write it by your own I recommend you to read ansys fluent customization manual, here you can find some examples there is a macro DEFINE_HEAT_FLUX which is not what you need, however, could be useful as a basis |
