I have a lot of trouble meshing this geometry. How would you do it? |
December 8, 2022, 08:45 |
Rep Power: 3 |
Hey all. I've been trying to mesh my geometry for a little over 6 hours now, and I still get into the same error. I have a cylindrical receiver geometry, which is essentially just a helical tube, inside a metal cavity, covered with insulation. What I want to do is I want to mesh a fluid zone inside the helical tube and create an air enclosure around the receiver. But I keep getting "The mesh file exporter could not resolve cyclic dependencies in overlapping contact regions. Please try to Repair Overlapping Contact Regions" . Based off of my trial and error, it seems to be coming from the enclosure, since when I mesh with just the receiver and the tube fluid zone, it seems to work "well" (and when I mean well, I mean it throws a different warning, "Note: zone-surface: cannot create surface from sliding interface zone. ").
I tried another, simpler geometry (essentially a square) inside an enclosure, and it did not throw any overlapping warning, just the "Note: zone-surface: cannot create surface from sliding interface zone. " Here is the STEP File if you'd be so kind enough to help. I've also posted the CAD pictures below just incase you don't want to open the file. Note: I created the CAD file using SolidWorks, and assembled the parts in SolidWorks Assembly. Here is the image of the receiver Here is the STEP file I used A little bit more detail on what I tried: *Made the cavity and insulation parts slightly larger so they do not touch on the sides (not quite sure if they touch on at the top, so I used a boolean subtract operation for those two bodies). *I also did a boolean on the tubes and the metal cavity. *Did a trial and error on which parts were the problem: > tried meshing the receiver without the fluid zone and air enclosure-- Seemed to work fine. > tried to mesh with the receiver and the fluid zone-- got the "Note: zone-surface: cannot create surface from sliding interface zone. " > tried to mesh the receiver and fluid zone, along with the air enclosure-- got the "The mesh file exporter could not resolve cyclic dependencies in overlapping contact regions. Please try to Repair Overlapping Contact Regions" error. *Tried to get put the enclosure on a simpler geometry (essentially a rectangle)-- got the - "Note: zone-surface: cannot create surface from sliding interface zone. " Last edited by rephical; December 8, 2022 at 08:49. Reason: Added the things I've tried |
mesh 3d |
[ICEM] Building geometry meshing problem | Yatharth Vaishnani | ANSYS Meshing & Geometry | 1 | June 12, 2016 06:33 |
[Other] solid deformed geometry for fluid meshing? | Awak | OpenFOAM Meshing & Mesh Conversion | 0 | May 30, 2016 09:22 |
[Workbench] Difficulties in doing Geometry Import and Meshing of a car | sankeerth2292 | ANSYS Meshing & Geometry | 1 | May 1, 2016 18:52 |
[ICEM] Imported geometry in Solidworks (CATPart) for ICEM meshing | lcaBR | ANSYS Meshing & Geometry | 1 | March 10, 2014 05:34 |
[ICEM] Meshing on a Complicated Geometry | tav98f | ANSYS Meshing & Geometry | 2 | August 17, 2011 11:15 |
