Error: No graphics functions are available. Error Object: ()
Like Tree5Likes
  • 1 Post By obylong
  • 1 Post By Mina_Mbg
  • 2 Post By LuckyTran
  • 1 Post By gfy001
Old   June 12, 2014, 12:05
Default Error: No graphics functions are available. Error Object: ()
obylong is on a distinguished road
I am having problems running my transient simulation of a bluff body with fluent in batch mode. An error message stated below comes up.
Error Object: ()
My journal file script reads like this;
; Read case and data files
file read-case-data Rc_transient.cas
solve/set/time-step 2.0e-4
solve/dual-time-iterate 100 20
Exit
ordinary likes this.
obylong is offline   Reply With Quote
Old   August 20, 2015, 05:21
Mina
Mina_Mbg is on a distinguished road
hi
did you solve it?
I have the same error!
Originally Posted by obylong View Post
Error Object: ()
Exit
Mina_Mbg is offline   Reply With Quote
Old   August 20, 2015, 12:24
Lucky
I think Fluent is trying to output graphics to the screen (probably the residual plot or monitor plots), but no graphics processor is available. Make sure you are running fluent without a gui (-nogui mode) or manually remove all graphics in your setup.
Old   August 21, 2015, 02:41
Mina
thanks for replying.
when I run it in HPC this error occured.Otherwise in my computer it runs and draw the residual graph.But I cannot continue running it with that.it may takes several weeks.
Doyou think it is a problemm of parallel solving or some thing like this?
If yes why it doesnt happen to other colleagues!
Old   August 21, 2015, 23:52
Lucky
Did you run in -nogui? i.e. 3ddp -nogui
Old   August 24, 2015, 02:43
Mina
Hi again,
I dont know what is nogui but it is 2ddp
Old   August 24, 2015, 08:45
Lucky
Then try <2ddp -nogui>
you must enter -nogui or else Fluent will think there is a GUI available and will try to output graphics. By entering -nogui, Fluent skips all graphics outputs even if you have them setup, like plots for monitors, etc.
Mina_Mbg and Jennifer Von like this.
Old   November 30, 2017, 00:50
yesenia
yesenia is on a distinguished road
did it work? I'm having the same issue and using -nogui did not solve it.
<fluent 3ddp -nogui>
Thanks,
Yesenia
yesenia is offline   Reply With Quote
Old   August 23, 2018, 05:00
Feiyu
gfy001 is on a distinguished road
you should include graphics when launching Fluent by adding '-gu' instead of '-g'. This solved my problem.
david112 likes this.
gfy001 is offline   Reply With Quote
Old   February 6, 2020, 00:44
WQW
wangqiaowei
WQW is on a distinguished road
Hi, I found same problem using HPC while it did not appears in my own computer.
the slurm is as followed
export FLUENT_GUI=off
/lustre/home/acct-ccelm/ccelm/wqw/linxi-fluent17.2/ansys172/ansys_inc/v172/fluent/bin/fluent 3ddp -t200 -g -i a135.jou -r17.2.0 -pib
I use GUI off, but in error file
Error Object: ()
Error: Case is not valid.
Error Object: #f
slurmstepd: error: *** JOB 320220 ON cas025 CANCELLED AT 2020-02-06T12:33:17 ***
WQW is offline   Reply With Quote
Old   February 6, 2020, 05:13
Default Could be due to animation or commands
  #11
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
This is also possible due to problems, such as, you have any commands given to setup an animation, or plot is enabled for any of the monitors. Check that only print or write is enabled for monitors and not plot.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   February 6, 2020, 07:01
Default thank you for the advise!
  #12
WQW
wangqiaowei
thank you for the advise! I found report file on just now, finally the problem is solved. Thanks!
Old   February 6, 2020, 07:14
Default Good
  #13
vinerm's Avatar
Vinerm
Nice to know.
Regards,
Vinerm
Old   December 21, 2022, 07:26
Thumbs up solved
  #14
Xilin Wang
Xilin Wang is on a distinguished road
this method is work well on my HPC. my problem was solved.
Xilin Wang is offline   Reply With Quote
Old   December 21, 2022, 07:46
WQW
wangqiaowei
thanks for the answer.
[Commercial meshers] CCM+ Mesh Conversion Ingenieur OpenFOAM Meshing & Mesh Conversion 17 February 2, 2014 09:34
Delta Functions within Ansys Mechanical Stephen Waite Structural Mechanics 2 July 29, 2013 08:56
field functions - table crevoise STAR-CCM+ 3 March 26, 2013 09:37
Field functions and table crevoise Siemens 0 March 20, 2013 10:51
User-Defined Functions Boisson FLUENT 2 January 18, 2002 22:09
