January 20, 2023, 09:11 |
Variable inlet temperature in Fluent
Yogesh
Rep Power: 3 |
Hello all,
Is it possible to define a non-constant fluid inlet temperature in Fluent? I'm running a transient simulation. My inlet temperature depends on the temperature of a cell zone and I know what the inlet temperature should be at different temperatures of that cell zone. I need Fluent to interpolate the inlet temperature between the ranges and not change abruptly (which I could even do manually). For example, At 650°C of cell zone, inlet temperature = 100°C, At 600°C of cell zone, inlet temperature = 80°C, At 500!C of cell zone, inlet temperature = 55°C, ...and so on. Thank you! |
expression, fluent - udf, inlet temperature, interpolation |
Question about Solidification/melting model in Fluent | yogesh03y | FLUENT | 0 | December 17, 2022 15:15 |
Unhandled variable DPM-dist | mahesh248f1 | FLUENT | 4 | July 15, 2021 10:50 |
[ANSYS Meshing] Fluent Conjugate heat transfer: Temperature at a small fluid region exceed limit | RPjack | ANSYS Meshing & Geometry | 1 | June 20, 2019 07:11 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
