Nose air flow (Respiratory cycle) simulation with heat and Humidity exchange |
June 2, 2023, 20:00 |
Ahmed Sameir
Dear All, Greetings. I would like to simulate the airflow of the nose using the following parameters:
Time: inspiration takes 1.9 s and expiration 2.3 s (4.2 s for one complete cycle). Temperature and Humidity: The inspired air had a temperature of 20 C and 30 % relative humidity. The expired air had a temperature of 35 C and a relative humidity of 100 %. The temperature of the nasal mucosa (Wall) increased from 30 C to 34C. The moisture of the nasal mucosa (Wall) was set to be constant at 100 % Pressure: To simulate the inspiration, a negative pressure is set in the nasopharynx (Outlet) between 0 and -10 Pa. This led to a flow speed of up to 2 m/s around the middle turbinate. For the expiration, the pressure in the nasopharynx (Outlet) was set between 0 and 10 Pa. I have successfully generated the mesh and defined the Inlet, Wall and Outlet. I would appreciate help setting the physics step by step. Especially how to make the model dynamic - expiration and inspiration. Include humidity and heat. I use Ansys student 2023, also have full version at school. I hope someone has time for this. Referring me to similar tutorials or posts is great too. Please check out this study for more information: https://drive.google.com/file/d/1nEI...ew?usp=sharing Best regards Looking forward to hearing from you soon |
UDF for heat and mass transfer, transient simulation | Akash Siddique | Fluent UDF and Scheme Programming | 7 | December 7, 2018 06:32 |
